Drive by wire to old school linkage?
Missing Linc'
Vernon
Im kinda getting tired of not really being able to pedal my way outta the whole and trying to find a 05+ Mustang GT throttle body so that I can have the same connections for the drive by wire. Would this be an easy change/swap? Im thinking of just getting the throttle linkage off of the first gen LS's and using it? But what about the PCM? Is there a way to delete the drive by wire signal or something like that? Thanks
ok well first to get the gt throttle body to work would require a custom machined adapter to fit it to our manifold, secondly you cannot swap to manual throttle unless you switch the entire system to the gen 1, also you will lose the variable valve timing and trans control which would be bad, there is room for improvement just get into the programming
