Driveshaft center support bearing replacement
dreigen
Columbus
I have a 2000 LS V8. My drive shaft center support bearing is shot. I have removed the drive shaft and trying to pull the bearing with a puller. The puller is not able to pull it off, is there a retaining ring on there somewhere? Maybe under the metal ring? I tried to pry that off and was unable to.
