driveshaft clearance issues
blackchariot88
charlotte
hello i just installed a 4"driveshaft in my 98 lsc and im having a horrible vibration over 70mph and it sounds like its rubbing on the gas tank as well any ideas on how to fix the issue with the clearance? Or do i have no other choice than to remove the shaft and start from scratch any suggestions will be greatly appretiated thank you.
i repositioned the gas tank no luck i even removed both safety loops from the car as well im still getting noise and vibration if anyone has had this issue with a 4" driveshaft please tell me how you fixed it this has been driving me up the wall for the past week
I assume the u-joints are new? Did you check the balance before you installed it?
