Driveshaft
Derrick Bagley
Des Moines, Iowa
Does anyone know what it takes to replace a factory driveshaft with a Metal Matrix driveshaft? Mine new shaft is coming Tuesday and I would like to have a general idea as to how this is accomplished.....any help would be great, thanks, Derrick.
I just dropped the gas tank a little bit, so that it would be out of the way as the shaft came out. I'm not sure if I had to take the exaust out, as I was doing a million things at once to the car. You just have to have enough room to drop the D/S down far enough to clear the rear end as you pull it out.
Mike
BTW....What shaft did you go with?
