themissinglink
I get the advance trac message, traction light and my abs light won't go out. I have an abs code reader and regular obdII reader.
I get the codes:
C1095 ABS hydraulic pump motor circuit failure
C1286 Booster mechanical failure
Does this for sure mean the problem is not a speed or abs sensor, something nice and easy?
P0401 EGR Flow Insufficient Detected
P1504 Idle Air Control Circuit Malfunction
P1565 Speed Control Command Switch Out of Range High
and another one for cyl 7 misfire
If you live in the La crosse, W.I. area I will check your codes for free!
I get the codes:
