EATC Code 30 fix
white127
Jacksonville
Ok my AC/heat doesn't work at all and accoring to the EATC out I have a code 30 on my 97 Towncar and I am trying to figure out how to fix it. Any ideas? If the Auto temp sensor is shorted is there a way to replace it with a manual one?
what is code 30
and describe what happens when trying to use the EATC in detail like all sounds
dimming of lights everything that happens
Error code 30 is Automatic temperature control sensor shorted
When I turn on the air or heat I get no blower action (so I admit it could be the blower) but the ac and heat both run and I can hear the mix doors opening or closing.
Tuen on the ac/heat and drive and you get air movenment and cold/hot air so all that works.
I'm just tying to find a way to disable the automatic temp sensor to see if that fixes the problem.
