Joeychgo said:Not good.
Alot of possibilities, but generally, its not good news.
DO you see any oil on the engine anywhere?
Did this just start or has it become gradually worse?
Check around the Oil filter - sometimes the rim seal there can leak
Try using LUCAS OIL STABILIZER, it stops most leaks and adds longevity to your car. I use all LUCAS OIL products and recommend it everyone I know.MrEvil said:My 2000 DTS appears to be eating two quarts of oil per month.... why is this I also have the faint smell of burning oil after a long run.......My check oil level message appears about every two months.
tha_saddle said:Try using LUCAS OIL STABILIZER, it stops most leaks and adds longevity to your car. I use all LUCAS OIL products and recommend it everyone I know.
here is alittle info on the northstar ....http://www.babcox.com/editorial/us/us100232.htm :dancefoolMrEvil said:My 2000 DTS appears to be eating two quarts of oil per month.... why is this I also have the faint smell of burning oil after a long run.......My check oil level message appears about every two months.
