Eibach Pro-Kit Springs
Uncle Vinnie
Canada
For all you guys that have intalled the "Eibach Pro-Kit Spring" in your car, was there any difference in the confort of the ride????
I'm thinking of getting them, but I'm not sure if I'm willing to sacrifice such confortable ride that we have with stock suspension.
Did you guys need an alignment kit after the installation????
Thanks
Thanks
Very slightly stiffer on my '06, not at all like a sports suspension, though. A little tighter in corners. I did not do the alignment kit, but will rotate tires more frequently. Note that I am still on the stock 17" wheels and stock grand touring tires.
A little bit of a stiffer ride on my 02, but it is worth it. The car sits lower and grips the corners better with no body roll.
Is there any rub with 18's and Eibachs with 2 peeps in the back seat??
StinkinLinkinLS01 said:
There shouldn't me much of a problem combining the Eibach springs w/ 18" wheels right?
I have had no problems with rubbing on mine, but the offset is as important as the wheel size when it comes to clearances.:)
