Detailed Image
We're excited to continue expanding in 2010 with two great product lines, Einszett 1Z and Brinkmann and many other new products.
Einszett
Einszett has a wide variety of products that many pro detailers enjoy and some unique ones to add to your existing products. If there are more 1Z products you'd like to see us stock, please let us know and we'll keep them in mind with our next order.
Einszett 1Z Anti-Insekt Bug + Tar Remover
500 ml Price $9.99
Einszett 1Z Cockpit Premium
500 ml Price $10.99
10 Liter Price $99.99
Einszett 1Z Glanz Wax
500 ml Price $19.99
Einszett 1Z Gummi Pflege Stift Rubber Care Stick
100 ml Price $8.99
Einszett 1Z Klima-Cleaner AC Odor Remover
250 ml Price $16.99
Einszett 1Z Lederpflege Leather Care
250 ml Price $16.99
Einszett 1Z Perls Shampoo
500 ml Price $9.99
Einszett 1Z Plastic Deep Cleaner Plastik-Reiniger
500 ml Price $10.99
Einszett 1Z Spray Wax
500 ml Price $11.99
Brinkmann
Brinkmann portable lights are the perfect compliment to any serious detailer. They will reveal imperfections with ease and help improve your results by showing you exactly what you removed or didn't remove. Much easier than lugging around bulky dual halogen light stands. The CREE LED TuffMax is an excellent option for both pros and enthusiasts alike.
Brinkmann Maxfire Dual Xenon Swirl Finder Spotlight
Price $26.99
Brinkmann TuffMax Dual LED Pivot Spotlight
Price $39.99
Other New Products
Meguiar's Professional Masking Tape
.7" x 180' Price $3.99
Poorboy's World Black Hole
16 oz Price $15.99
Poorboy's World White Diamond
16 oz Price $15.99
DI Accessories Clay Bar Storage Container
8 oz Price $2.49
Lake Country Pro Glass Polishing Kit with Rain-X
Price $39.99
Chemical Guys Wet Mirror Finish
16 oz Price $19.99
Chemical Guys XXX Hard Core Paste Wax
8 oz Price $24.99
We look forward to bringing you even more great products throughout the year. If you have any questions on any of the products or need a hand putting together some products to best fit your needs, please do not hesitate to ask.
Thanks for reading!
Greg @ Detailed Image
Einszett
500 ml Price $9.99
- Paint safe pre-wash degreaser that effectively helps loosen stubborn contamination prior to washing
- Avoid scrubbing to remove tar, bugs, etc. which will minimize adding swirls and scratches to your paint
- Safe to use on head lights, chrome, glass, rubber, plastic and paint surfaces
500 ml Price $10.99
- One of the best interior cleaners and protectants that leaves your finish factory new
- Easy to get streak free results every time, great scent, and UV protects
- Best used on your dash, gauge cluster, navigation screens, audio components, shift knobs, arm rests, leatherette, steering wheels and much more
500 ml Price $19.99
- Protect and shine your paint with a versatile sealant packed with high quality carnauba wax
- Easy to apply and remove, works best when applied thinly with a foam applicator pad and removed with a quality microfiber towel
- Helps protect against road grime, tree sap, salt, carwashes and UV fading
100 ml Price $8.99
- Restore and care for rubber trim and seals to keep them elastic and looking like new
- Protects against extreme temperature and UV rays
250 ml Price $16.99
- Eliminate bad odor from vents and your AC system simply and effectively, leaves you with a pleasant odor for months
- Follow directions exactly on the label for optimal results
250 ml Price $16.99
- Clean and condition your leather in one simple step leaving behind a clean non-greasy finish
- Best used on coated leather, leatherette, motorcycle cladding, handbags, and boots
500 ml Price $9.99
- High lubricity, pH balanced, and added protection makes this an excellent maintenance shampoo
- Low sudsing formula that helps soften hard water leaving spot free shine
- Use approximately 1 capfull per gallon of water for optimal results
500 ml Price $10.99
- Optimally clean virtually any plastic surface with ease while leaving behind a natural, factory new finish
- Works great on wooden trim, pedals, door trim, lower valances, kick panels, shift knobs and much more
500 ml Price $11.99
- Excellent maintenance product over a sealant or wax, to enhance depth and gloss while extending protection
- Easy to apply and wipe away streak free, best applied after a maintenance wash
Brinkmann
Price $26.99
- Easily reveal swirls, scratches and other imperfections with this lightweight rechargeable hand held spotlight
- Avoid having to use bulky, corded, and hot halogen light stands!
- Get the best polishing results with the proper lighting, no guess work if imperfections have been removed effectively
Price $39.99
- Dual LED light will reveal swirls, RIDS, holograms and other imperfections in your paint
- Uses 6 AA batteries that are included, making it easy to get back into action. Pivoting heads and CREE LEDs make it a must have for detailers.
Other New Products
- Properly protect trim, emblems, lights, adjacent panels and more when polishing or using a buffer
- Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
- Perfect for protecting clear bra edges so you don't get product build up that shows
16 oz Price $15.99
- Enhance the depth and gloss of darker colored vehicles with ease
- Best used after polishing and before applying your layer of sealant or wax
- Easily applied by hand or machine and removes effortlessly
16 oz Price $15.99
- Enhance the depth and gloss to lighter colored vehicles with ease!
8 oz Price $2.49
- Secure screw top ensures no air penetration or leaks
- Store many clay bar pieces in one 8 oz jar
Price $39.99
- Effectively polish away light swirls and scratches in glass. Works great on water spots as well!
- Includes an adapter for most rotary and random orbital buffers
- Protect your glass with Rain-X glass sealant
16 oz Price $19.99
- Clean and protect your paint in one simple step while enhancing the gloss and depth
- Easily apply by hand or with a buffer and remove with a quality microfiber towel to reveal a mirror like finish
- Works great on both light and dark colored paint for a head turning finish
8 oz Price $24.99
- Perfect mix of gloss and depth, durability and ease of use
- Looks great on light or dark colors and is one of our best bang for the buck waxes
- Best applied with a foam applicator pad and removed with a quality microfiber towel
Thanks for reading!
