Engine coolant temp sensor.
MrWilson
NJ
Wheres it at, any pics? not hard to replace?
It's one of the sensors in the coolant crossover tube in the fron of the motor. This is the one that wraps around the alternator.
I BELIEVE it's the drivers side sensor.
Mike
Temp sensor - which goes to the computer, is on the passenger side of the crossover tube.
Temp sender - which goes to the instrument gauge, is on the drivers side of the cross over tube.
The sensor will have a plastic connector with 2 pins.
The sender will have a little 90deg rubber connector, with 1 wire.
k thank you very much.
my hid keeps telling me that my engine coolant is low, and i ran it through my diog program, and it says that my problems may be comming from the engine coolant temp sensor.
Is your plastic reservoir filled to the top. The lowest cold level is only about a 1/2 inch from the top.
