Hello, I have a Lincoln LS 2001 V8 and I had the engine serviced some months ago for a misfire in the engine. The misfire caused my mileage to go down to like 8 mpg. But I had it repaired and the mpg went back up to the usual 17 mpg.
Now, there a misfire dealing with, I believe, another cylinder.
Does anyone know what causes a misfire (ignition coil/spark plug brand, using regular gas instead of premium, driving long distances, letting the car idle, etc.) ?
And if it's the ignition coil/spark plug causing the problem, what's the best brand to get, or should I let a mechanic replace the problem?
