Ran into a problem with my 95' a few days ago. Engine over heating, only cold air from the heater. My thinking, thermostat. Spent four hours changing the damn thing and I've still got the same problem. Any thoughts on what's wrong. Thanks.
94m5 said:Cold air from the heater has always pointed to LOW coolant. But since you replaced the t-stat, you NEED to bleed the air out of the system.
CSimonGo said:In the front of the engine compartment above the water pump is a metal tube with poly hoses connecting to each side. It has a round plug for bleeding , hope that helps.
