Engine swap
HARLEYMAN
REDFORD
DOES ANTONE KNOW IF THE ENGINE OUT OF A 2005 LS 3.9 WILL WORK IN A 2000 LS IF SO WHAT NEEDS TO BE CHANGED:confused:
NO IT WILL NOT! The electronics are different and the gen II has variable cam timing.
Heads, intake manifold with TB need swapped. Whatever sensors are on the Gen I block. Block will work heads won't. 02_Linc has an 06 block with a Gen I top end swapped under warranty.
Don't you own a repair shop? Should you be more informed than most of us?
