Engine won't start (Is firing & fuel press OK)
ghatch
louisville
94 TC. Was pulling out of driveway the other day when engine sputtered like running out of gas and shut off. At same time, saw a small puff of smoke coming from under left side of dash (wire burn). Engine restarted for 2-3 seconds and shut off again. Would not start thereafter. Have not located burnt wire yet but checked fuel pressure and was 40 PSI. Checked plugs to see if firing and they are. Have not found anything electrical that doesn't work yet. Where do I look next? If you have a checklist, please list in order to check. (I'm getting too old for these aggravations and I need to get this car running quickly.)
