ridindirrty
Hello everyone. Having some issues with my climate control. Initially I would fire up the heat and the yellow lights on the control box would start blinking. Determined through research this indicates a fault of some sort. Most of the time it would work fine but like any problem it's getting progressively worse. The issue appears to be with the blend door being out of position as the heat does not go where directed
. Other times it works absolutely flawlessly which makes me think it could be something like a dirty connection. Ever since i've owned the car the temp display has had a habit of flashing back and forth between celcius and farenheit but there has never been a problem with the heater functions themselves. Anyone had a similar experience? What's involved in getting that control box out
? Thanks for any suggestions.
