dannoltie
Hi all im new to this forum and have a quick question regarding my 2002 Lincoln LSE with the 3.9l dohc v8....When starting the car when cold you have to crank the starter over for longer than normal for the car to fire up, this only happens after the car has sat for over an hour for example if i run in a store and go to start the car when i leave it fires right up normally. I would appreciate any input that you guys can give me on this issue i replaced the fuel filter yesterday and it is going into the shop on Monday to have the plugs swapped out to new factory motor craft ones...could this excessive cranking be caused by the high compression motor? I am new to owning one of these cars as I am used to driving trucks and when u turn the key they start right away.
Thanks Dan
Thanks Dan
