Exhaust Part #'s???
Motodrew
Council Bluffs
Hey fellas. I'm looking for the magnaflow & dynomax ultra-flow muffler part numbers that you all are using on your LS8 setups. Not the whole kit, just the muffler itself. If no part numbers, then what size/diameter/length etc??
Appreciate the help!!
d r e w
With the Dynomax Ultraflow you will need the part#17279 or similar. If you dont replace the whole system its hard to match up. The LS exhaust at the muffler goes down to about 1 7/8" to 2". If you get a 2" a muffler shop can mate the 1 7/8" pipe into the 2" muffler. Any muffler with these dimensions will work.
You need a 2" center inlet /side outlet with a 14" case length, 18" overall to fit behind the wheels properly. + tips and proper hangers and welded into place.
Good Luck :)
I know the Ultraflow has fiberglass packing. Anyone noticed any break-down in the material thus creating any change in exhaust notes?
