jruppert
Haven't had the 03 v8 very long. I've noticed if windows are down and run it hard from stop to 60 or so, I get an awful rotten egg smell. Do you think this is more to do with plugs and coils or catalytic converter?
Ok, well I do have plans on doing the plugs soon. I have thought about replacing the coils as well but havent made any definite plans. One night while driving around 50, I did get the code, cant remember which one and what it was called, but the info that I got on here referred to it as coil interference with TPS or something like that. Has not come on since.
Also, just curious on the performance of this car.. With the traction control off, should I be able to break the tires loose when taking off? It is a real dog up until 3k or so.
It doesn't seem to have too much trouble coming loose under brake torquing.
They dont have to be clogged to fail...
and to the OP.. i wouldn't be worried about "breaking them loose" until you get it running properly (CATs,coils, plugs). beating on it with these problems is just asking for problems
