Harlem1Der
what's up fellow LS enthusiasts. Yep I'm gonna revisit the ol coolant leak issue with this car. I have changed everything plastic: Degas Bottle, Upper and Lower Radiator Hoses, Both coolant tubes (the one that the upper and lower hoses connect to as well as the one behind that with the PITA rear bolts), thermostat housing, etc. Over the past couple weeks, I've developed a leak. This was when I changed the rear coolant tube (PITA rear bolts), as that was the last plastic piece that I hadn't changed. Well I've changed that out, along with the lower gasket and the upper o-ring and I'm still getting a leak in that area. I can't pinpoint where exactly it's coming from due to the tubes being in the way while I have it running with everything hooked back up. The only indication I get of where the leak may be coming from is that its dripping down the block. I've changed the water pump so I know it's not that because I can see a small pool of coolant above that part. It's leaking to the point that I'm going through a bottle of coolant every day-day and a half. I really don't want to get rid of this car, but I'm starting to feel like it's about that time. Plus this is giving the wife all the ammo she needs to try an convince me to get rid of it. Please help me out. If there's any questions about what else I've done, please let me know. Thanks in advance.
