For Sale Feeler: Thunderbird SC Clutch & Brake Pedal Assembly
98BLKLSC
United States
Hey guys.
I bought a Thunderbird SC clutch and brake pedal assembly recently. It has the master cylinder and reservoir with it.
I have decided to keep the 4r70 in my car instead of swapping to a TR3650.
Is anyone interested? $150 + shipping.
Let me know. Thanks!
For those interested, the brake pedal is almost worthless for this swap.
The mount holes do not match the MarkVIII's brake booster and firewall. You can cut the padoff and swap and weld it to the mMarkVIII's pedal arm, but that's it.
Mike
Mike
Thank you. I did not know that, but when I bought it, it was a package deal.
Agreed on the brake pedal.Its just better to mod the one in the car because of the mods the t bird pedal assy would need.I am in the process of having this done now.The pin on the clutch pedal will be another issue if it is worn out.Mine was and had to be welded up and then turned back down,and yes you have to remove the pin from the pedal to rebuild it.I want the 5 speed in my Mark so I will put up with the cost and aggrevation.It will be cool.
