Few Q's on LS KONCEPTS
Oxyargon03
Pittsburgh
I would like the tinted tail lights do they fit an 02 LSE ? Also, the angel eye conversion kit. It looks awesome on grey's lse. Do you just need to buy the ndizma (spelling?) kit or is there more. What is the black sealant they are talking about? I have the black rubber seal around the plastic that seals the headlights is that it?. Thank you
i believe he said that under the rubber sealant there is either a grey or black colored sealant.. not rubber.. and if its black u cant do it.. if its grey u can I BELIEVE.. not 100% sure.. as far as th tail lights.. the 02 LSE and LS have the same tail lights..
if he had the headlamps u could just do that instead
The tail lights will fit any 2000-2002 Lincoln LS or LSE. As for the angel eye kit you will need to have the grey sealant around the headlights. The black seal you see is just to seal the engine compartment once the hood is closed. If you look at the three square holes on the top of the headlights you should see some sealant coming out of those. That will tell you what you have.
