mayhawboy's LS
Just wanted to let you guys know that i just performed the first mod. on the LS. My airbox now has thirty-five 7/8" holes in the bottom half. Didn't want to cut the entire bottom out so i opted for the next best thing. I took a 7/8" spade type drill bit and drilled the holes, centered in the ribbed squares (if you've looked from the inside of the airbox without the filter you see what i mean) and along the bottom side under the wrap around air nozzle going to the fender. This type bit probably wasn't the neatest (had to take a knife and trim around the holes to celan them up), but was pleased with the results. Now when under heavy accel. i hear just enough throat from the engine to make me grin even more than i did before. Next mod. i either plan to cut the resonators off and replace with straight pipes or install a new system with replacement speakers and subs. Can't go too crazy, my wife drives it too. Very conservative she is. Thanks for all the tech. info.
