First time at the track last night
Nitrobasher
St. Louis
Hey guys and gals. I went to the track for the first time last night and dunno weather to be happy or dissapointed.
After looking around the sight i see that my 60' is really good, but my 1/8 is bad
Here are the slips:
First run (3 hour cool down)
R/T... 269
60'... 2.181
330... 6.453
1/8... 9.975
MPH... 70.15
1000... 12.985
1/4... 15.514
MPH... 89.31
second run
R/T... .170
60'... 2.223
1/8... 10.064
1/4... 15.609
MPH 89.09
3rd run (hot lappin)
R/T .015 :D :D
60'... 2.314
1/4... 15.754
Last run
60'... 2.218
1/8... 10.019
1/4... 15.552
MPH... 89.19
Does anybody think it could be the Ram Air mod? shoving air down the throat at unnesasary times?
These were all tooken by the profesional photographer at the track
http://www.racingperspectives.com/c..._017.jpg&img=&tt=&tfile=tn_BKD6-06-27_017.jpg
http://www.racingperspectives.com/c...48.jpg&img=40&tt=&tfile=tn_BKD6-06-27_048.jpg
http://www.racingperspectives.com/c...82.jpg&img=80&tt=&tfile=tn_BKD6-06-27_082.jpg
http://www.racingperspectives.com/c...83.jpg&img=80&tt=&tfile=tn_BKD6-06-27_083.jpg
Nice R/T's, The 60's are pretty decent too. Your trap speeds are those of a low 16 second car. Id try taking the ram air off, and putting a K&N in it.(if you dont already have one) Oh and I noticed that when i left overdrive on along with traction control. My car ran a 15.1 compared to the 14.9's that it was pulling previously that afternoon. It looks like your car starts to slow down toward the end of the track.
i agree, cept for the cheepshot at the ram air :)
sounds like you dont have the top end hp that your supposed to. any cels?
btw, good racin. glad you finally got to the track.
With that 60' you should be in the high 14s even with a Gen II. The trap is low but I wouldn't say 16 sec. range. My LSE does 15.0 with only 93. I would guess either a tune up or a weak fuel pump or something is not allowing it to pull full WOT potential. That 2.1 60' is very good.
my brothers mark vii trapped at 89 and ran a 16.1 when it was stock.
Gearing, weight and traction has alot to do with it. Your right thats a low trap with its weight and power, it typically pulls harder in the second half of the track, thats how you can tell its running out of power. My 78 Mustang ran 14.7 with only 92.
Its got 100k miles on it. With the stock Fuel pump i believe. I dont know what to do I heard that changing a fuel pump is a pain in the ass!?
Is it a 1 day job or what?
True, There are too many variables to base one car's times and speeds on another.
thats about the same as my 98 lsc my best was 15.2 but that was bone stock, air silencer and all just wanted a base line, yup us gen 2 guys got the short end of the 1/4 stick but we got the better trans AH HA HA HA HA AHHHHHH HAAAAA HA HA HA
have you ever changed the filter?
mine picked up 2mph from a basic tune (plugs, fuel filter, injector flush, decarb)
it only had 23k on it and the filter had been changed once (fram. yuck)
I agree the 60' is great but trap and ET are low. What kind of weather and track conditions were you experiancing at the time of the runs?
MrWilson said:
goin with fuel pump possibly?
You know it Bro. With that mileage the filter and pump are done. The MPH totally reflects the lack of under a load fuel delivery/pressure.
ONEBADMK8 said:
You know it Bro. With that mileage the filter and pump are done. The MPH totally reflect the lack of under a load fuel delivery/pressure.
Filter in wheel well or in the tank/screen? I'm at 92k, I did the fuel filter not to many miles ago. I'm putting in a 255 Walbro in the tank soon, already have it, just have to do it once shes running again. Is there a filter/screen I should get and do when I tackle it.
Is this that common that its a no brainer? I'm doing mine regardless as more mods are going to follow.
Ice the intake manifold. The difference can be pretty significant.
*edit* - I agree with the fuel pump comment. I had a car exhibit similar symptoms and a fuel pump swap made it feel like a new car again.
You should be around 15.0-3 @ 93-5 mph for a stock 98 LSC. Great 60' times. Pull the DTC codes, and I suspect you might find that your IMRC's are not opening up. No CEL will show, so check anyway. Your mph is way too low. Use Seafoam, and Lucas Top Cylinder lube and fuel system cleaner. Change your air filter, loose the ram air mod, and change your PCV, fuel filter, spark plugs, and you should run these times all day long. I have a 98 LSC, and had this happen to me. Good Luck.
good info but you will get a CEL when the IMRCs dont open.
Sorry to disagree, but I did not get a CEL when my IMRC's did not open. I found the code on my SCT Xcal2 pulling DTC's, but never got the CEL. I verified they did not work by data logging the IMRC's via XCal2 to my lap top computer.
edit: I see in your sig that you have a 95 Mark. It might be true that you get a CEL on a 95, but on a 98 OBD2, no CEL.
actually im a tech for an FLM dealer. we get CELs for IMRC failure every once in a while.
my last 1 was on a 96 (IIRC) windstar.
I had a P1519 code - Inlet Manifold Runner Control Malfunction (Stuck Closed). When I went to the track, this was my BEST time while the IMRC's were stuck closed with stock BTC0 tune and no CEL. Had me scratching my head since there was no CEL. Checked and cleared DTC's, and did the aforementioned pm - then checked for DTC's again - none this time :) , and picked-up 3 tenths like magic:
Stuck IMRC:
60'..........2.282
330.........6.559
1/8........10.004
MPH.......73.30
1000......12.944
1/4........15.394
MPH.......91.78
Not Stuck IMRC:
60'..........2.346
330.........6.465
1/8.........9.806
MPH......74.58
1000.....12.635
1/4.......15.019
MPH......94.09
