Hello,
I just bought an 04. I can't say that I know everything about cars, but I've always done all my own work on the ones I've owned so I know how to turn a wrench. I've also been doing some (a lot) searching on this site to see what I could find on this issue. Here is my problem and what I've found:
I've been having a hard time starting the car (hard starting). It would turn over, but never fire. I was frustrated because it was fairly random. Sometimes it would start after about ~20 seconds of cranking, sometimes not at all. I thought "it's cranking, so the battery is OK. It must be something else. My searches here led me to believe it was a leaky injector or fuel pump (I was praying that it was neither of these since these can be expensive problems to track down). The other common "solution" I found on this site was a possible problem with the alternator. Easier to track down but still an expensive part. Then I remembered when the car was delivered, the truck driver jumped it to get it started. So I decided to buy a $30 battery charger and charge the battery over night. Guess what....Problem Solved (mostly). Let me explain. I still think there is a problem with the battery (maybe not putting out as many cranking amps as it used to). Sometimes, normally when the HID lights, the stereo and the interior lights are on, the car still has some problems starting. But, when I turn everything off, no problems. This is what I've seen in the short time I've owned the car. I hope this helps.
Tony
