Ford/lincoln keypad entry
billvaughn
Palatka, Fl.
Has anyone added the keypad entry that ford offers to their LS??? I know they are stickon and I assume they are programed to the vehicle like a universal remote for a tv or vcr....Is that correct??? Thanks
I love my wife's lincoln!!!!!
Yes - I did. Got it off e-bay. It really is just another remote key FOB.
The LS is the only Ford that you cannot add a new key FOB yourself, you have to take it to the dealer (with all the FOBs) and they use their computer to add it to the PCM.
Yeah i got one off ebay for $60.00 very well worth it. Now I dont have to pay when my wife locks the keys in the car yet again! Really she has only done it about 4 times in the last year....
No, the FOB is user programmable. I just did this last week with a fob I bought off eBay. In my 2004 manual there is a procedure that can be done to program them your self. The manual is wrong in the directions however. They say turn the key to I think position 4(just before the start position) anf then click it back and forth from off to 4, eight times. What they should really say is start in off and click back and forth to 4, eight times. YOu know you got it right when the door lock cycles off and on. Then you just click any button of the fob and then click another fob or as many fobs as you got, upto 4 fobs.
It is the keys you can't program unless you already have 2 keys that work. So big warning to you all, MAKE SURE you always have at least 2 keys, or you gget to pay the dealer something like $70 for a second key. If you loose all your keys, you have to have the car towed to the dealer to get news keys made.
Good Luck,
Jim Henderson
Jim - for the pre-03s you can add new keys yourself but you cannot add new remote FOBs. I am assuming he is talking about a pre-03 since he is asking about adding a keypad - the pre-03 didn't come with them.
Here what my 01 manual says:
To add another remote FOB:
Replacing lost transmitters
If a remote transmitter has been lost and you would like to remove it from the vehicle’s memory or you would like to purchase additional transmitters for your vehicle (up to four may be programmed into memory), take all your vehicle’s transmitters to your dealer for programming. It will be necessary for your dealer to reprogram all the remote transmitters to your vehicle while performing this service.
To add another key:
spare keys
A maximum of eight keys can be coded to your vehicle. Only SecuriLocky keys can be used. To program a coded key yourself, you will need two previously programmed coded keys (keys that already operate your vehicle’s engine) and the new unprogrammed key(s) readily accessible for timely implementation of each step in the procedure.
If two previously programmed coded keys are not available (one or both of your original keys were lost or stolen), you must bring your vehicle to your dealership to have the spare coded key(s) programmed.
Please read and understand the entire procedure before you begin.
1. Insert the first previously programmed coded key into the ignition and turn the ignition from 1 (LOCK) to 4 (RUN) (maintain ignition in 4 (RUN) for at least one second).
2. Turn ignition to 1 (LOCK) and remove the first coded key from the ignition.
3. Within ten seconds of turning the ignition to 1 (LOCK), insert the second previously programmed coded key into the ignition and turn the ignition from 1 (LOCK) to 4 (RUN) (maintain ignition in 4 (RUN) for at least one second but no more than ten seconds).
4. Turn the ignition to 1 (LOCK) and remove the second coded key from the ignition.
5. Within 20 seconds of turning the ignition to 1 (LOCK), insert the new unprogrammed key (new key/valet key) into the ignition and turn the ignition from 1 (LOCK) to 4 (RUN) (maintain ignition in 4 (RUN) for at least one second). This step will program your new key to a coded key.
6. To program additional new unprogrammed key(s), repeat this procedure from step 1.
If successful, the new coded key(s) will start the vehicle’s engine and the theft indicator will illuminate for three seconds and then go out.
If not successful, the new coded key(s) will not start the vehicle’s engine and the theft indicator will flash on and off. If failure repeats, bring your vehicle to your dealership to have the new spare key(s) programmed.
In 03 they added the procedure to add DIY FOBs:
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of four) available before beginning this procedure.
To reprogram the remote entry transmitters:
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 2 (OFF) position to 4 (RUN).
4. Cycle, eight times, rapidly (within 10 seconds) between the 2 (OFF) position and 4 (RUN). Note: The eighth turn must end in the 4 (RUN) position.
5. The doors will lock, then unlock, to confirm that the programming mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the procedure over again.
7. The doors will lock, then unlock, to confirmthat this remote entry transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 2 (OFF) position after you have finished programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming
so i have a 2000 Lincoln LS... if i buy the kepad entry thing off ebay, do i need to take it to a dealer... how much do they charge???
i thought about buying that, but when i was reading the description, it says it CANT be added to pre-03 LS's without reprogramming something.. and that sounded VERY expensive!
Quik LS said:
right - the dealer charged me $40.
10-4 Quick, mine is a 2002.. The dealer wants 199.99 for the keypad, install, and program....Going to find out what they want just to program...
SolacE said:
My dealer hit me for $79.99 to program 2 fobs and the keypad as well as put the keypad on the car...JERKS!
that really isnt that bad. i thought it would be much more to do 2 keyfobs PLUS the keypad. ...
