This is an '88 LSC... probably 322K miles (maybe 422K). New long block about 40K miles ago. 5L HO engine.. car runs fine in all respects.
On occasion, the front airsprings will deflate overnight. It's been a rare thing. Over the years, I have attempted to trace the system's problem a couple times.. Ran the diagnostics as instructed in the service manuals.. never found anything.. the system checks out 100%. Anyway, I'm pretty much familiar with the spring-system.
But recently a new clue has come to light.
If the car has been parked beyond an hour or so (beyond where controller/airsprings are auto-adjusting themselves although ignition key = off) and IF i put a bag of groceries or similar.. maybe 8 lbs in weight on the left of the hood, overnight the spring will completely deflate.. without fail.
Weight on the left-front hood results in left front spring deflating (right-front seems to hold air. Right side ends up a inch or two higher).
Spring will not deflate if the body is just violently shaken up and down.. there's gotta be some constant, extra weight bearing down on the front end.
I'm thinking the trouble is something with the control module or front leveling sensor, but it's just a wild guess. My thought is the leveling sensors detect a trim imbalance, the control module opens a valve-solenoid and allows a slow leak. However, how could a solenoid open if the entire system is inactive?
Hopefully someone in here is so familiar with this system they might have some idea..
Simply put, extra weight on hood = spring slowly deflates.
This forum helped me a few times. The How-To rebuild the power window motor gearbox was sweet. So, i got faith.
Thanks in advance..
Thanks in advance..
