Kiss4aFrog
I have a 94 Mark III that I wanted to replace the air struts on. I went ahead and ordered a pair and when they arrived I started to remove the leakers. Up until I tried to get the bottom bolt out of it's rubber mounted sleve in the lower control arm things were going as expected. I ended up bolting the old ones back in as I can't get the bolt to seperate from the sleeve. I've tried oil and a good quality 1/2 drive impact but the rubber bushing seems to absorb the impact. Anyone else run into this and have a solution other than taking it to the dealer and letting it be their problem?
Help!
			Help!
