Mill1978
Sometimes when I come out in the morning I find my frontend sitting on the tires and sometimes she doesnt drop at all. I even cut the airride off and she still dropps sometimes. Im lost and need advice. !!!!SKNAHT
If my bags are bad why do they only leak sometimes?.
Procrastination is not your friend when it comes to air ride.
This is an easy problem to fix, not EASY doesnt mean CHEAP.
you need two new front bags.
you can put two bags on it and fix it.. or you can wait..and then you'll need
2 bags
compressor
air ride relay
air ride computer
putting off the repair only means your gonna spend MORE money to fix it.
Right now you can fix it for LESS than a coil spring conversion.
Keep putting it off and it's only gonna get MORE and MORE expensive.
If your bags are good, how do they leak "sometimes" that doesnt make any sense either.
Trust me.. or hell go do a search.
your reply "it only leaks sometimes" is the same reply given all the time.
There are alot of variables which could effect why it did or didn't leak down.
Temp, position the car was parked in..it goes on and on.
Here is the deal.
Turn your air ride off..(just like you said you did)
IF the car falls.. you have a leak.
it's pretty cut and dry.
there is a slim possibility that you have a bad solenoid 0 ring.
99% of the time they dont fail, unless the solenoid has been removed.
I know you dont want to "THINK" that you have a leak.. I too have been there.
you could change the solenoid o-rings and there's a very SLIM chance it'll fix it.
There.. I've given you a "gliimmer of hope" now, your bags might not have a leak.
In the end, your gonna find that ONE of your bags is leaking.
If you turn the key on..engine off..and let the car pump up from the pancake position.. if you listen very closely you'll be able to hear ONE or BOTH of the bags "hiss" as they pass thru the area of the leak.
It might be a very faint hiss... it might only happen for a split second. you might have to do this a few times before you catch it.
..in the end.. your gonna find you have a leaking front strut.
you might get away with chunking a single strut on..I've done it.
Sorry to be the bearer of bad news, but.. "it IS what it IS".
Im not. I figured if there was a leak it would do it all the time.
Personally, I'll take hands on experience over edjumakation any day of the week.
I am speaking from over a half a million driven miles in the mark 8.
When you drive one of these cars and have to fix one yourself..for that many miles..you start to "notice a pattern".
I do have plenty of hands on experience. And I've had a personal experience on my mark when it was frigidly cold the BRAND NEW bags would leak... and the car dropped 1.5-2 inches below curb height. NOW tell me that my brand new bags which were ordered from American air with brand new o rings were defective. You're pitting experience(which doesn't mean much to me or anybody) against logic and concept.
Ok mr physics major, since you know so much about how cold affects rubber o-rings.. explain to me why you cant figure out why a bladder full of warm air tends to deflate quite a bit when it cools down considerably.
Now before you spout off about the air not being warm..
put your hand down on your cold compressor and keep it there while it jacks the car up...then come back and tell me that air in the system isn't pretty hot.
That is probably why the air ride computer allows the car to make adjustments for up to 1 hour after it is turned off..so it can adjust the height while the bags cool down.
THAT is why the brand new American Air bags that were not leaking.. sagged a little bit.
Jeez it's not rocket science.. hell it aint even model rocket science.
