lees LSC
after i purchased my lincoln from my father in law"the car sat for 4 yrs. in garage" the front brake caliper's froze on the way home and alot of heat built up. the next day i replaced both front caliper's,pad's and had rotor's turned. about two week's ago i started to get a humming noise comming from the front end while the car is driving. all of the tires are still like new and are goodyear's of the same size and type so i'm going to rule them out. do you think the front spindle bearing's could be getting worn or possibly damaged from the past brake problem? i also just checked the power steering reservoir and it was o.k. but the fluid looked dirty but no leak's. i'm taking the car next week for a fresh alignment and a power steering flush. should i wory about the humming? it's not loud or getting any louder, just a little annoying.any help would be appreciated before i pluck down the buck's for something i may or may not need :L
