My search did not turn up anything so here is my problem. I have a vibration in the front end of the Gen2 LS, it is barely noticeable at really slow speeds about 5mph then goes away. It is more noticeable between 60 and 70 MPH. Before 60 it is not there, after 70 it is not there, worst at about 65. The feedback is through the steering wheel, you can see the oscillation in the 60-70 range It has stock 16" wheels. It needed tires anyway, so I replaced those. No change to the vibration. Rotated the front tires to the back, no change there either. I looked at the front end, nothing jumped out at me. I took it to the shop, guy there checked it out and could not find anything wrong in the front end. He agreed there was a vibration, but said everything looked fine. He suggested getting an alignment or maybe a bad tire, but tires are new and the problem was there with the old tires so I doubt that is the issue. There is no noise that I can detect, but I would like to get it fixed. Any suggestions on what else to check?
