jayyy_k
I got an 05' Lincoln LS I just replaced the front passenger window regulator but used the same motor cuz there was nothing wrong with it got it all together pretty self explanitory only comes out and goes in one way but when i roll the wondow up ususaly i push the switch and it clicks forward and that makes it roll up the rest of the way by itself same with rolling the window down but this time it stops as soon as i let off the button. the way down it works. the way up it doesnt, wierd. on top of that when i roll the window down to its lowest point the wondow doesnt go down into the window stripping, just the top left corner sticks out about a quarter inch. when I roll the window up to the top, it hits the top but the rolles down a small amount then stops. like i said all bolts are in the rite holes i adjusted the windows multiple different ways, one side lower then the other but nothin works. could this be somthing easy please tell me so, i need help and any would be appreciated. Thanks
