Front struts
Gray Mist
New Braunfels
Just starting to look into replacing the front stuts on my 88 BB. I'll also change rear shocks to match.
I want to do the best change possible and upgrade would be a plus.
ANy inputs????
Sorry dude, I just got back in town from San Diego. It was nice out there.
Anyway, it depends on what you want to get out of it. Stock replacement parts like motorcraft are fine. KYB GR-2's fit, and will give you a firmer "upgrade" to the handling. Monroe Sensatracs would be the middle ground, with a bit more than stock and a bit less than KYB. That's for "standard" replacements without going into the endeavor for Koni struts. You may want to consider replacing the rear if you go beyond stock, though.
