Front wheel bearing bad, which one?
LSTony
Sellersburg
I remember reading a thread here on how to determine which one it is by turning but for the life of me I cant find it now.
Whats happening is there is a noise coming from the front end that gets louder as you go faster, if turn right the noise goes away and if you turn left it get louder.
My guess is the driver's side. Mine is doing the same thing. I changed the passenger side bearing, and the noise still remains. Going to swap the old pass side bearing to teh driver's side one. They are interchangeable.
Most of the time its the opposite side that you think it is.
I just change them both, if one is bad the other is going to be soon.
lol. This is what happened to me. I was trying to nail it down where the sound was coming from. I thought it was driver's side, then thought "it's always the opposite one", so I switched the pass side bearing. Now I gotta use the pss side bearing on the driver's side to see if it goes away.
I'll have to jack it up and check it, I just had it in pep boys a couple weeks ago before I parked it to do the timing chain job and during the last snow we had here the right side wheel slid into a curb and they ended up having to put a new inner/outer tie-rod on it (side to side movement) and a sway bar link on that side that got dislocated from its bottom bushing.
Turned out to be the pass side one as I suspected thank god as that mofo was a fuggin bitch to get out :mad:. Now all I gotta get done is the rear brakes and hopefully I'll be set for a while. Gotta do the front brakes on the wifes van tomorrow tho :(.
made total sense that it was the pass side. When you turn left, the weight/stress goes to the passenger side, hence the noise when you turned left.
