FS: 20's driv royales
fyi, They are only 8.5" wide, and they won't fit a Mark with stock brakes as they hit the caliper bracket. I used to own a set... ;)
the box they came out of said 9.5 on it? they wont fit a mark 8? i wanted to buy one just to put them on it? if yours where 8.5 and mine are 9.5 would they fit on a mark8?
If they are indeed 9.5" which I'm pretty sure is wrong, they are wider and would rub the front upper spindle too I'm pretty sure as they are really close with 8.5".
Even with really thick spacers and shaving the caliper brackets up front they still rubbed slightly in this pic below. I would have had to get thicker spacers and longer wheel studs and shave the brackets for them to work:
thats 8.5 you cant measure the width of a rim by measuring the tire, to measure a rim you measure from the bead lip to bead lip, any tire on any rim is always gonna be wider than the rim itself.
Try looking on the backside of the spokes of the wheel , normally you will find size and offset stamped on them.
your right it says the rim size on the backside of the rim on the lip 8.5x20
I wonder if they will fit now that I have Cobra brakes? Want to trade for a set Giovanna Dalars? To bad we weren't closer to check :(
i dont need rims LS is gone traded my car audio for a 1990 bronco need funds for repairs make offers?
