FS: Complete nitrous system
m_maker
Farmington Hills, MI
I am pulling the n2o system off the car I just bought.
It includes a complete NOSzle Direct Port E.F.I. Nitrous System, made originally for SOHC, but adapted to DOHC engines.
Jeff did awesome job installing this and everything works as it should.
Here's what's included:
NOS 4.6 NOSzle Direct Port Kit Adapted to DOHC http://www.holley.com/08100NOS.asp
Maximizer II Progressive Nitrous Controller http://www.fjoracing.com/products/Maximizer2/
FJO NOS Pressure Sensor
NOS Purge Valve
NOS Bottle Heater
NOS Automatic Bottle Opener
Kit is complete and needs nothing.
I tested the system several times, and it works awesome. With the jets installed it showed a solid 110rwhp and even more TQ. The shot comes on smooth and the power climbs just like with the vortech kit thanx to the progressive controller. Bigger gains are possible with simple jet change/tunning.
There is easly $2000 invested in this setup. It is one of the best nitrous kits available, the main kit alone retails for $1400. Too bad I had different plans for this car, otherwise I would've kept it.
If the buyer is interested, I can include an x-cal_2 by SCT with the nitrous tune that can be used on obd2 cars. For gen 2 cars I will include the upper intake manifold that has a spacer welded into the base to allow fuel rail clearance. Gen 1 cars will work fine without it.
Best reasonable offer.
