driller said:Are you putting the gauge on the fuel rail?
Removing the schrader valve - you need a 1/8" NPT male fitting to screw into the fuel rail. Most fuel pressure gauges will have 1/4" NPT male threads, so typically you require an adaptor - 1/8" NPT male X 1/4" NPT female. Brass or stainless steel.
Where are you putting the gauge? If you need the AN adaptors, find a dealer that has the complete line of Russell fittings.
http://www.russellperformance.com/
95LSC32V said:I'm looking to put it on the fuel rail but i'm afraid of hood clearance problems. This is the one I got: http://store.summitracing.com/partd...art=SUM-800160&autoview=sku&Ntk=KeywordSearch. It says it will screw into any 1/8 NPT female port...
1wykdmk8 said:Wait a minute.....I thought the fuel rail was a 1/16" NPT vice a 1/8" NPT. If that is the case you will need the same adapter that driller used to mount that gauge..... :Beer
