Fuel Pump , Air Cond problem.VAR.Load Mod.
windcloudrdr
Moulton
I am a new member.I posted in the welcome . So I will te\ry it here. I have a 96 mark VIII with a start problem I know the problen which is the Fuel pump does not work an the Air cond won't come on.I had a dignastic ck done . an thay said I had a bad Varable Load Control Module problem Part# F6LF-14B239-BC an said there were no new ones avaliable, an said that thay could fix the fuel pump problem by grouning one of the wires going to the module which thay did.The car worked fine but no air Cond. I found a used module part#F3LF-12B577-AH in a wrecking yard an installed it out of a Mark 1994 year. I checked with the dealer thay said it would work just a diferent part number but same module, I installed it same problem so I'm thanking the module is not the problem, In fact with the ground connected the module don't even have to be connected, I'm not sure even if it'n needed except for the pump Ground an Air cond or maybe it don't even run them. If anyone has had this problem maybe thay can shed so light on it for me. Any information would be appricated. Thanks for any help you might give. I bought the car new, I've had very little problem with it It has 110,000 miles on it. THANKS. Jerome (Windcloud(
Jerome. You are correct, you need the F6 P/N and there are no new units available. IT has been obsolete from ford for over 6 years now. If you still have your original unit, you can send it out to be fixed. Otherwise you have to search the wrecking yards for a 96 vehicle. The f3 and f4 p/n's will never work on your vehicle. They only interchange between 93/94/95 model years. 93-95 are OBD I, EEC 4. 96/97/98 are OBD II EEC 5. And No, you can't use a 97/98 unit.
I am In need of a1996 Mark111 VLCM part F6LF14B239 If anyone has one that works please let me know E-Mail windcloudrdr@bellsouth.net. I tried a 1994 all opf you are right it won't work Thanks for any help you can give. windcloud
