"They changed the fuel pump relay. Only time will tell if it was my problem."
Did the shop discover the relay to be bad all on their own, or did you suggest it?
I was looking at the wiring diagrams and the pump-relay/EEC relay connection has it's own test lead. I think a bad relay will spit out a code on a Code Reader, and there's little doubt the shop hooked one up.
My problem with low-rpm shut down might be explained in the manual, but it's kinda difficult to interpret. Here's some stuff the manual says:
Technically, there are 2 fuel pump relays. One is inside the EEC (electronic engine control), and one is external. They work together, depending on operating conditions.
When the ignition is in the OFF position, both relays are open (no power).
Turn the ignition ON, and the EEC relay closes. This powers/closes the external fuel-pump relay and starts a timer. The fuel pump runs (since the pump relay contacts are closed).
If you don't turn the key to START within one second, the timer disconnects power, the relays open, and the fuel pump is de-energized, and it shuts down.
That one second is long enough to pre-pressurize the fuel system, but the pump cannot continuously pump fuel with the key "ON" and the engine off.
Turn the key to START, and the EEC module operates the pump-relay to provide fuel while cranking.
After the engine starts and the key falls back to the ON position, power to the fuel pump is again supplied by the fuel-pump relay (that relay stays closed and power to the pump is continuous).
After that, the EEC senses engine speed, and shuts off the fuel pump by opening (grounding) the fuel-pump relay if RPM falls below 120 RPM, or if you turn the key off (and kill the engine).
So it looks like starting and low-RPM fuel pump operation are not as simple as it might seem, since the EEC computer controls and monitors a few things.
Ain't nothing worse that wondering if the car will start.. I know I was worried about it for a long time.. even after that relay was replaced... but I never had another starting problem.. knock on wood.
Good luck with yours.
