hillfolk
Hi all,
I am having a hell of a time getting info and changing the delivery fuel pump on the 2000 LS. I have determined for sure that the pump is the issue. I have tried to remove the fuel lines from the top of the unit with no luck. As I understand it, I should squeeze the two tangs and lift the tube straight up to remove. The tubes don't want to move.
I also need to know how to remove the whole assembly from the tank. I purchased a shop manual online but am quite disappointed in it as it lacks sufficient detail.
I sure could use advice on the fuel pump or a decent manual available as I don't want to pay the dealer to change it if I can do it myself. Below is a pic of the two lines.
Thanks in advance, Dave A
