Fuse question
3.9-LS
Wilmington, NC
My LS still has a parasitic battery drain. First of all, the check charging lite is not on. It charges fine. I checked all of the mini fuses with my multimeters millivolt setting to check voltage drop. The only 2 that showed anything were in the PCFP. Fuse 20 which is REM, and fuse 33 which is switch backlighting. Why would 33 show a voltage drop?
