Fuses
LennDawg
Syracuse, New York
where are the fuses located in the LS (i have a 2000)... i kno there is a box near the spare tire and probably one under the hood, but i could have sworn there were some under the steering wheel? im trying to fix my little problem with my car unlocking when i lock it and locking when i unlock it... do you know where the specific fuse for the locks are, if there even is any?
the locks arent even a fuse, are they? i looked the the fuse diagrams in the manual and none of them mention the locks... what else would cause my locks to be in reverse like they are?
does this happen when you use the remote? when all doors are losed and you are inside the car... does it do the same thing?
the lock on the inside works perfectly... maybe i should have mentioned i have an aftermarket car alarm/starter key pad thingy... and when i hit unlock on it the doors lock and the lights dim out... when i hit lock, the doors unlock and the lights come on... so i have been just putting in my key and unlocking/locking it that way... any suggestions??
