Gas Cap?
Calabrio
Sarasota
Does the gas cap eventually wear out and will this affect either the fuel effeciency or the accuracy in which the Mark VIII tracks fuel consumption?
In my case, I never have heard any release of pressure when removing the gas cap from my Mark VIII, as I do in my other car, despite having installed a new 255lph fuel pump.
Also, the computer is recording inaccurate gas mileage and fuel consumption. It's been reading about a full gallon difference between what it displays as being consumed versus what it takes to top off the tank. After 60 miles last night, this difference meant a posted mpg of about 27, though it actually was about 21.5 mpg.
My cap seal went out on my 00 stang. Drove like crap till I replaced it. Actually I believe it caused the pump to die an early death ( 65K) because I let it go for a week.
Stangs don't have a mileage calculator so don't know if it would make any difference.
I went out and open my filler on my 98 LSC - no noise, but it has been off overnight so not a true test. I will drive it and then pop the top and will post if it hisses.
You may hear a SLIGHT hiss (as in earlier post) but nothing extreme. Just a slight vacuum.
That DOES NOT affect gas mileage.
When you top off a tank - there will be air pockets on the very top. Thoes MPGs are only estimates - don't take them seriously (from the car) just use your own. That is the best it can come up with!
I don't think I've ever heard a hiss come out of my filler... As far as I know it's not "supposed" to. I didn't know they could go bad, can they really?
