Gas milage
lilwheezy75
Feasterville
Im looking for some easy ways to get some better gas milage for my car.. i drive the car well i dont slam on the gas or breaks and i try to conserve gas.. but it still seems to do pretty bad.. what are some good ways to up my gas milage?
Change O2 sensors
Clean MAF sensor
Change air filter to K&N or other high-flow
Change spark plugs to stock temp, platinum. Use Motorcraft only!
Change wires.
Synthetic oil like Mobil 1 and filter
Engine block heaters- they can help reduce cold consumption during startups.
Seafoam in the tank and into the intake manifold.
alright... sounds good.. How do i change the O2 sensors and MAf sensor and where can i get some? I plan on getting a Kn from a friend of mine soon and I just changed the spark plugs.. but nothing special got all new distr cap and wires. Im getting an oil change soon too. and where can i get a block heater? ANd can i do this work myself?
How do i change the O2 sensors and MAF sensor
Have someone else do it. It's a bloody knuckles job- let someone else bleed to death. MAF you can do yourself. Just disconnect the connector from the airbox assembly, remove the torx bits, spray the MAF sensor with electrical cleaners, and you're done.
From a Ford dealer/ accessorizer..
try summit, or jegs! if they do not have them you can try and give max at 5-star a call, and if he does not have one.... i am sure they are somewhere on the net! google is your friend
