chump2825
im getting around 17 the best and its all high way on crusie controle. the computer says i get 19.6 but i dont. any have an idea what could be wrong.
JERSEY JOE said:I was getting 27 + but all of a sudden it dropped to 24. I drive the same place every weekend and it all highway for 300 miles.With cruise and a/c on I was getting consistant 27+. Now the same exact trip without a/c I get only 24 . Any ideas?
Don't you get hot? it's a lincoln you gotta have a/c!!chump2825 said:i drive with no ac all the time.
Brozly said:Mine went from a strong 28 to 26+, it's currently at 25.4 for a couple thousand miles, I had the trans fluid changed, and an alignment just before it dropped, I think the allignment is off a bit... (feels a bit Loose), it's after 5 when I get home and everybodies closed, if I leave it, I'm stuck in the truck @14mpg/diesel, so...
I filled up this morning,... 16.93 gal, said I could still get 12 miles.
I hate to stop for gas Everyday when I can make it two... (barely)
Do these all have the same size tank??, is there a larger one that will fit??
