aggiestckl
Cant say enough about theese, just put one on and what a diff.. most deff an improvement over napa's bullsh*t they sling... would highly recomend one if in need of a belt.
torquemonkey said:Gatorback
Replacement Products for LINCOLN MARK SERIES - 1997 4.6L V 8 OHC Eng
Part No. Applications Usage Footnote Metric Part No. Replace By
Poly-V Belts
4060980 Poly-V 6PK2490
Tensioners
49236 Tensioner
Idler/Tens Pulley
49006 Tensioner Pulley
49006 Idler Pulley
Molded Radiator Hose
60942 Lower, Radiator to Tee Cut to fit. 208003
61156 Upper Cut to fit. 504166
DAYCO Products Catalog - Passenger, Car, Light Truck, Van
LINCOLN MARK VIII - 1997 - V8 4.6L 281ci GAS FI N V
Belts / Tensioners / Pulleys
Part Number Description
5060975
Belt Routing Diagram Multiple Accessory
89007 Idler Assy. Pulley
89007 Tensioner Pulley
89218 Automatic Belt Tensioner
Radiator / Heater Hose
1 1/2 IN. W.P. to Tee
70081 Rad. to Tee
Cut to Fit
71686 w-w/o A.C.
71687 By-Pass, Tee to Upper Pipe
71688 Fill Bottle to Tee
81121 Rad. to Tee
81151 w-w/o A.C.
