gen 2 tweeter question
chicken
SHEOOOOOOOOT
northern illinois
i blew my driver ft tweet and found some old ones that i had lying around, so i swapped them out and everything sounds good now but whats the deal with the huge boxes the tweets are mounted in is it just a box or is there a crossover inside. just curious if anyone out there has cut one open? :Bang :Bang :Bang :Bang :Bang
I'm interested reading about what you find. Is it for mounting, resonance or what? I thought that the cross-over was in the amp set-up under the dash for JBL.
well for all 84 people that looked i used a precision hammer and opened up the box and found that it is just an empty box that holds the tweeter
A resonance chamber? Or is it that Ford has a "valued engineered" standard inner door skin/structure that is die stamped and the box is a generic mounting point?
Its and enclosure for the tweeter, to direct the sound toward the passengers. The crossovers are built into the amp I beleive.......
sure now someone knows what it is, after everyone looked and nobody said nothin and i destroy mine then someone chimes in and says what i allready know now
LOL - yeah - but you destroyed a bad speaker - who cares :)
All I know, is that they are a real PITA to put aftermarket tweeters in that spot.
not unless you take it to a shop that knows what they are doing!
i dont think they would fit in there anywayze the factory ones are actually quite big and the kenwoods that i put in are little bittys
