its pretty straight forward. install the intake, move the cruise control box so that you get enough slack to install it on the TB, ( i used the cobra TB, so YRMV if you use the Mark's) cut the stock throttle cable/cruise cable bracket so that it mounts on the cobra intake facing the right way
i used the cobra IMRC box, so i can remove the intake, fuel rails, injectors and IMRC's as a unit. i had to lengthen the IMRC controller cables so that they would reach under the intake.
you will need to modify the fuel lines so that they attatch to the cobra rail on the passenger side rather than the drivers side like the marks rails.
the wiring harness cover on the drivers side needs about 2" taken off of it on the front to clear the IAC tube
i am EGR delete, so i didnt mess with that, just blocked that off on the intake.
hope that helps..
