Gen2 grille
Because most people don't listen to the right/easy way..
well even with a stubby, the bumper cover slides over the steel inner core and the foam so getting to the screws is gonna be damn near impossible, just take the bumper cover off.
jamie is right. take the 10 minutes it takes to actually pull the bumper cover off, you will thank us later.
If you use the extra 7 minutes granted by K9t8@uz3whatever you're just lazy
OK, that being said, does the panel above the grill and headlights come off with the bumper or can it be left on?
that panel will remain in place... just remove the four nuts holding the grille to the panel while removing the bumper cover
