GenII Console - how do I remove the liner?
Frat-man-du
Gainesville
I want to replace the center console lid hinge (my spring broke). I cant see how to remove the fuzzy inner liner. I removed the rubber mat and the two screws on the bottom - what else?
If I remember correctly , remove the arm rest from the hinge and pry out the liner !
Good Luck,
Sonny
Still wont budge I used a large putty knife and a couple screwdrivers to wedge around the lip, but it just wont budge -at least w/out breaking. The whole console lifts up (since the lower screws are removed). This should be a sinple task. There must be something holding it on.
