skymasteres
Now I am in trouble. I have the whole climate control box out from behind the dash and I can't for the life of my figure out how to seperate the upper and lower half as per the shop manual's instructions withought braking it.
The shop manual refers to seven screws and all of the fastener clips. When I look at the figure for the assembly it only shows all of the things that mount to the box when the two halves are together. There is no diagram showing where these seven screws are.
I can see all the way around the seam and I only see several clips. The other problem is the assembly seems to have been glued together at the factory.
Has anyone done this before?
